Grease Zerk Solution?
   / Grease Zerk Solution? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Well, if nothing else I found out a couple of things with my PT today. First is a neat trick. You can get the seat to go all the way sideways (45 degrees) if you reach under the front of the rear right tire and depress the seat level plunger. This full extends the seat cylinder causing the seat to tilt way the heck over. I may now be able to get the grease gun in.
Second part is that the striking of the zerk on the bars under the seat may be a fluke. For those with the 1850 (and I assume the 1845) we do indeed have a "jesus" nut on the lower coupler. Mine was kinda loose (probably 3/4 of a turn). The new Boston Tools wrench showed up. Frikin monster. But I think it raised the height of the seat as I tightened things up. But who knows, its a PT.
But this all said, I won't be able to test results as the zerk was busted clean off at the base and I can't find my easy out kit.
   / Grease Zerk Solution? #2
Carl,
Big thanks for the tip on tilting the seat. I will try it tomorrow.
Ken
   / Grease Zerk Solution? #3
Can you get enough clearance to install a hose and route it to the outside for future lubrication?
I don't think so. On the PT the seat rides is attached to the front of the tractor, but the zerk is attached to the back of the tractor, so the arms brush the zerk when you turn. When you turn on a hill it gets worse as the seat is tilted to accomodate the slope of the terrain...
Carl
Makinex Power Lifter (A52377)
Makinex Power...
1999 KENWORTH T800 DAY CAB (A53426)
1999 KENWORTH T800...
2011 Jeep Wrangler Unlimited 4x4 SUV (A51694)
2011 Jeep Wrangler...
2015 GMC Acadia SUV (A51694)
2015 GMC Acadia...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
