grease your balls or not
   / grease your balls or not #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I know this is a personal question but do you grease your hitch ball or not?
   / grease your balls or not #2
Yes. With the heavier BP trailers I pull, upto 25,000#, I have seen them loosen. I use Reese Ball Lube. Same jar has lasted me 10 yrs.
Chris
   / grease your balls or not #3
Sure helps it stop squeaking. I grease it with clean grease each time before hitching up the gooseneck. Afterwards l wipe it all off and stow the ball under my rear seat. I wipe out the gooseneck coupler also, as it usually has some dirt blown up in there.
hugs, Brandi
   / grease your balls or not #4
Just so they don't rust.
More important - Are your balls big enough? Don't use a 2" where you need 2 5/6. And almost ALL balls in the big box stores are 6,000lb rated balls, or less, even the 2 5/16.
   / grease your balls or not #5
It will noticeably reduce sway.
   / grease your balls or not #6
I don't. Grease attracts dirt and the dirt will grind away and chafe your balls.
   / grease your balls or not #7
Short trips no, but when I am going 20 miles or more I will. CJ
   / grease your balls or not #9
Critical to use the right kind!
   / grease your balls or not #10
U don't have to but I have a pull truck that has a 1,300,000 miles and the gooseneck ball has major wear .
Sent from my iPhone 5 using TractorByNet
(APPROX 100) UNUSED LANDHERO T-TOP BOLLARD (A51248)
(APPROX 100)...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
250 GALLON FUEL TANK (A51247)
250 GALLON FUEL...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
