Grease On Hood
   / Grease On Hood #1
JDGreenGrass
Veteran Member
Maine
John Deere 770
Apparently I rubbed some grease onto my hood and it is a bugger to clean up.
What solution should I use to get the hood clean once again.
The JD Green isn' so green right now and I ain't likeing it.!!!!
Distilled alcohol.??
   / Grease On Hood #2
I'd pick up some kind of quality automotive bug and tar remover, maybe something by Meguiar's. Anything that's formulated for a car's paint will be safe to use on your tractor. Just another reason to keep a coat of wax on the tractor.
   / Grease On Hood #4
Starting fluid.
   / Grease On Hood #5
I've used WD-40 with great success but I will advise you to wash the area after you clean it :)
   / Grease On Hood #7
I wouldn't use brake cleaner, but would use Simple Green.
Or I'd use gasoline too.
   / Grease On Hood #8
I'd use some diesel or kerosene and follow up with some soapy water. Dawn dish detergent is good for cutting what's left of the grease/diesel.
   / Grease On Hood #9
If John Deere paint is the same as the Yanmar paint, you couldn't hurt it with anything short of a sand blaster. The Yanmar paint is the thickest hardest paint I have ever seen.
   / Grease On Hood #10
Palmolive, or Dove Dishwashing liquid with water. ~S
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A53473)
Greenworks...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2014 MACK GU713 WINCH TRUCK (A53843)
2014 MACK GU713...
1999 FORD F-450 SUPER DUTY SERVICE TRUCK (A54756)
1999 FORD F-450...
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
