grease lube job zerks and ***Pins***?
   / grease lube job zerks and ***Pins***? #1
ohbehave
Knoxville, tn
Kubota L3200 (2012)
I just finished doing the 50 hour service on a Kubota L3200.
The grease-gunning of the zerks went well, but after some web browsing, I see people referring to greasing "pins", too.
What's a pin? (I'm a newb, btw)
Are there other things that could use some lubing (whether grease or other)?
   / grease lube job zerks and ***Pins***? #2
Greasing the FEL has metal Pins the hold the joints together and flex. Just give the Zerks three pumps every 10 hours and you will be fine.
   / grease lube job zerks and ***Pins***? #3
These "pins"/pivots are about 1" in diameter. They are surrounded by the FEL trunnions. They are fed grease through dedicated zerks.
   / grease lube job zerks and ***Pins***? #4
You got the pins if you hit the zeros on the FEL. Pins are the pivot points of a FEL.
Chris
Oh, ok... good.
I just thought "pins" were something other than "zerks".
I made sure to grease every thing that had a zerk.... even the tucked away, hard to find ones.
Some folks seemed to describe the "zerks and pins" when referring to their grease job. I just didn't know what "pins" meant.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
JLG 1255 Telehandler (A55218)
JLG 1255...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2010 International Prostar (A47477)
2010 International...
2021 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2021 PRINOTH...
