grease lube job zerks and ***Pins***?
   / grease lube job zerks and ***Pins***? #1
ohbehave
Bronze Member
Knoxville, tn
Kubota L3200 (2012)
I just finished doing the 50 hour service on a Kubota L3200.
The grease-gunning of the zerks went well, but after some web browsing, I see people referring to greasing "pins", too.
What's a pin? (I'm a newb, btw)
Are there other things that could use some lubing (whether grease or other)?
   / grease lube job zerks and ***Pins***? #2
Greasing the FEL has metal Pins the hold the joints together and flex. Just give the Zerks three pumps every 10 hours and you will be fine.
   / grease lube job zerks and ***Pins***? #3
These "pins"/pivots are about 1" in diameter. They are surrounded by the FEL trunnions. They are fed grease through dedicated zerks.
   / grease lube job zerks and ***Pins***? #4
You got the pins if you hit the zeros on the FEL. Pins are the pivot points of a FEL.
Chris
Oh, ok... good.
I just thought "pins" were something other than "zerks".
I made sure to grease every thing that had a zerk.... even the tucked away, hard to find ones.
Some folks seemed to describe the "zerks and pins" when referring to their grease job. I just didn't know what "pins" meant.
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
2018 DODGE RAM 3500 LARAMIE SERVICE TRUCK (A51406)
2018 DODGE RAM...
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
2020 Isuzu NPR Heil 8RLDB 8CuYd Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
