Grease is a mystery to me
   / Grease is a mystery to me #1
zuiko
Platinum Member
Minnesota
JD 990 4WD
I got the JD Lithium Grease (the regular stuff) for my 990. I would like to be able to use one grease for everything (tractor related or not). Is this the grease to use or should I have got something else? The mechanic I talked to at the dealer thinks its good stuff. I think the manual recommends low-clay something or other. /forums/images/graemlins/confused.gif
Thanks.
   / Grease is a mystery to me #2
Zuiko; In my opinion any lithium based grease with EP2 additives will work in almost all applications, except constant submergence in water( I don't think you are planning on that...are you /forums/images/graemlins/crazy.gif). That's my 2 cents worth!!
   / Grease is a mystery to me #3
Agreed. Also, I think it is important to point out that not all the grease fittings have the same requirements. At one end of the scale is u-joints. These have seals and contain rolling element bearings. Once a year is on the prudent side. At the other extreme is the lower loader pins- these are typically not sealed, and live in a harsh environment, and should be lubed daily or at about 10 hours of loader use.
   / Grease is a mystery to me #4
Graphite or a moly grease is better in extreme conditions and only costs about $1 more a tube if that TSC has it for 1.29 a tube. But any lithium #2 grease will work.
   / Grease is a mystery to me #5
The tech at my selling dealer told me the polyurea high-temp works for everything and that mower spindles should receive at least a high-temp moly. No. 2 is the minimum standard, as everyone else indicates.
   / Grease is a mystery to me #6
I get the Black Stuff from the JD dealer. I use it in everything and it seems to work great on my trailer bearings. They tell me at the shop its the best stuff JD has. Dave
Do you know what the black stuff is? The stuff I got is pink and translucent.
   / Grease is a mystery to me #8
Hi
I went to the JD dealer and tried to get the different greases that the manual calls out. The JD parts guy didn't seem to be familiar with all of them. He did have several on the shelf and I ended up purchasing the polyurea since it was rated for the extreme pressure on the loader. I have used it for the steering linkage and pedal linkage as well.
The dealer greased everything fresh for me on delivery, but it didn't appear to match the greenish blue hue of the polyurea.
John
   / Grease is a mystery to me #9
For what it's worth when I was in the Air Force we used Moly grease on everything!
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A55852)
2012 Ford F-450...
ANTIQUE GAS FIREPLACE HEATER (A57192)
ANTIQUE GAS...
2016 Chevrolet Tahoe (A56859)
2016 Chevrolet...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
2010 Hyundai Elantra Touring Sedan (A55853)
2010 Hyundai...
2025 Swict 60in Bucket Skid Steer Attachment (A55851)
2025 Swict 60in...
