Grease from TSC
   / Grease from TSC #1
cat2
Trying to find a good grease. How is the moly-lithium grease from tractor supply? Also how is the shell rotella grease? the name of it is something like lithium two?
   / Grease from TSC #2
What do you want the grease for? Moly greases are not good for some high speed uses.
   / Grease from TSC
It is not going to be for high speed. using it on my skid steer
   / Grease from TSC #4
I think that if you ask 10 very good mechanics this question, you will get at least 9 different answers. Personally, I like the Kendall Super-Blu.
I would find a grease that works for you and stick with it. If you mix greases from incompatible base stocks, you could run into a problem.
   / Grease from TSC #5
I use TSC's Traveller brand red high speed grease. I buy it by the case. Works fine for me. I have never bought their moly grease.
   / Grease from TSC #6
Hi.
In the heavy equipment business I never used any thing but red silcone based grease and still do. It stays where you put it, unless it jumps on you.
   / Grease from TSC
What kind of problems:confused:
   / Grease from TSC #8
Cat2, there are numerous good threads on grease selection if you use the search feature.
Problem of mixing incompatible greases is that the resulting mix may be either too thick or too thin to work right. This problem is largely solved by more frequent greasing when you switch, to flush out the old grease.
If both greases are the same base, such as lithium complex, there should be no issue. FWIW a great many common greases are lithium complex.
Moly or no moly is your choice. Moly is generally highly recommended for areas that get large impacts, like loader pivot pins. I'm not aware of high speed problems for moly that Snowridge alluded to, and in fact I have a can of wheel bearing grease (for on-highway wheel bearings) that is heavily moly fortified. If there are high speed issues I'm sure it's at a much higher speed than any greased part on a tractor operates at.
I personally use JD brand grease because it's easy to find, low cost, I can actually find its specs on JD website, and I trust JD. However I would imagine that most if not all greases sold in reputable stores would work fine, as long as you buy one that is labeled for your type of use. Meaning, buy a heavy duty type grease, with or without moly, avoid the greases that are specifically marked as light duty.
   / Grease from TSC #9
   / Grease from TSC #10
In fact, you don't even have to use the Search feature. On the very first page of this forum is a thread with 41 replies entitled "Grease; Please educate me"
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55302)
2020 New Holland...
12in x 16.5in Kubota RTV-X1140 Tires (A52377)
12in x 16.5in...
Ammco Brake Machine (A53424)
Ammco Brake...
CATERPILLAR 615C MOTOR SCRAPER (A51406)
CATERPILLAR 615C...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
