# grease fittings on BX23
   / # grease fittings on BX23 #1
Silvergrizz
New Brunswick, Canada
BX23
Thought this subject was covered before, but could not find after doing a search. My manual indicates 22 fittings on the BH, but I found 23. Extra 1 not indicated was at the bottom of the cylinder that is inside the boom. FEL I found 10, but have seen references by some to 12. I could not find the fitting on the pedal as indicated in the manual. Is it really there? I found a total of 33 fittings. Is that all of them? Got 11 hrs on the new machine and want to keep things right. Thanks
   / # grease fittings on BX23 #2
On the front end loader tip your bucket down,and there are two that you cant get at unless you do this...is that what you were looking for? If not look at the loader and image every moving part,youll find it.
Sitting on the tractor,right under the left side of your pedal,in the middle is a grease fitting.I use white lithium in this one,wont be so stiff in cold weather,same grease used in snowmobiles.Ionly do this cause i got some ,i wouldnt buy a tube of it special
ALAN
Found the two on the bucket that you referred to, after some thought this morning I have concluded I got them all. Think those referring to 12 on the loader must have two cylinders on the bucket and not 1 like the bx23. Will have another look for the 1 on the pedal after I get back from work today. Thanks much for the response.
JMR 72" Root Grapple (A50121)
JMR 72" Root...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
P.T 8' Offset Disc Harrow (A50120)
P.T 8' Offset Disc...
John Deere 6175M (A50120)
John Deere 6175M...
