Grease fittings on a 1500...
   / Grease fittings on a 1500... #1
RandyH
Cordova, Alabama
Yanmar 1500
Are the grease fittings standard 1/8th NPT threads or some kind of metric?
Thanks,
Randy
   / Grease fittings on a 1500... #2
They're just plain old standard grease fittings.
   / Grease fittings on a 1500... #3
Beg to differ. The Zerk end is standard, but that end which threads into the tractor, which is what 1/8 NPT would reference, is indeed metric, 6mm as I recall.
   / Grease fittings on a 1500... #4
Well, you're both right. Those on the Yanmar tractor and factory implements are metric, those on the additions such as an FEL, back-hoe, post hole digger, rotary cutter etc will most probably be US standard fittings.
   / Grease fittings on a 1500... #6
OOPS!!! Of course you guys are right, I was only thinking of the grease gun end. They're plain old standard metric zerks.
   / Grease fittings on a 1500... #8
I have 8mm zerks on my fel and have broke a few cuz the grease gun latches on to them so tight... The zerks on the tractor I have not had any probs with so I don't know what size they are. Folks here say 6mm.
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
LMC LOT NUMBER 237 (A53084)
LMC LOT NUMBER 237...
