grease fitting size ???
/ grease fitting size ??? #1
gibby123
Nova Scotia, Canada
Kioti CK 25 HST
I am looking for the specs on the grease fittings in the loader arms of a KL 130 loader. This is the fitting that is resessed into the pin . Any tech support will be of great use. Looking for thread size and pitch.
/ grease fitting size ??? #2
can get them thru Lumax Lubrication.
They are a 10mm X 1mm taper thread grease fitting.
Ordered mine thru Amazon. com Part no. LX-3313 included free shipping at the time. $47.00 for a box of 100. They are tighter than the brass fittings that are in there but they actually thread in.
Most of the metric assortments that you buy do not have the taper threads.
/ grease fitting size ??? #3
TSC has 6mm, 8mm amd 10mm metric grease nipples. About $1 each in 5 unit qty. Bought a set of each yesterday.
Does the 10mil fit property into the threads. All of the people I have spoken too have told me that the taper is what is important ! Did yours fit right ?
/ grease fitting size ??? #5
The Kioti fittings have a European pipe thread. There are a few previous threads about it here. I get mine from the Kioti dealer because, to me, the few cents more is not an issue.
/ grease fitting size ??? #6
I have the same problem, Went to dealer, got wrong fittings from them as well. I agree with deputyrpa might be some kind of European thread pattern, have tried metric threads, and did not fit, not sure about the metric taper though. If that is the trick, I would like to find the right size. A little of a pain to keep switching them out to grease the tractor.
/ grease fitting size ??? #7
Krafty,
Have you tried them and do they fit correctly?
/ grease fitting size ??? #8
Yes,
The original fittings are brass, they are easily deformed when they are put in, They are a taper thread. The Lumax part number is a steel taper thread. they fit properly but because they are steel may not seat as deep as the brass ones. That is they do not deform as easily as the brass fittings do. I have not been able to find the brass fittings.
I have found lots of 10 mm with a 1 mm taper\pitch . They all have a 11 mm hex . The 10 mm deep socket is the only socket that will fit into the grease fitting ports on the FEL . Still look'in ...:mad:
/ grease fitting size ??? #11
ahhh grease fittings, what a sore subject for me,
I can only get grease to go into about 50% of the fittings, I have fought to no end with it, and of course most of them get destroyed when using the fel and BH, like the ones on the stabilizer feet get mashed crushed, snapped off.
and to boot Kioti uses 3 different fitting sizes depending on what one you want to replace
ugh
ken
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 579...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
