Grease Fitting Missing?
   / Grease Fitting Missing? #1
JagAlfaOwner
Roanoke, Virginia
New Holland TZ24DA
I just put my 60 In Belly mower on my TZ25DA. It had grease fittings on only 2 of 3 the Blade Bearings (directly on the blade spindle). Is it possible mine sheared off somewhere or is this normal? I do not remember last August when I greased it last. Any one checking theirs would be appreciated. There were several on the Deck that I got but I am wondering just about the Spindles as I believe they are the one's most needed.
AL
   / Grease Fitting Missing? #2
I would expect all of the spindles to have grease fittings. I would think you could find it by feeling around. It shouldn't be too hard to remove and replace. You want spindle greased.
Andy
   / Grease Fitting Missing? #3
If they did shear off.. just get a zerk tool.. it usually has a extractor, thread chase, and 2 sizes of wrenches onthe ulti-tool..there is one for sae nd metric.
soundguy
   / Grease Fitting Missing? #4
Not familar with that deck...but some gearbox driven decks have the zerk for the center blade down low, off to the side below the gearbox.
JohnnyB
UNUSED RAYTREE RHBC72-72" BRUSH CUTTER (A51248)
UNUSED RAYTREE...
UNUSED JCT 72" VIBRATORY PLATE COMPACTOR (A51248)
UNUSED JCT 72"...
2014 CAT  299D TRACKED SKID STEER (A53843)
2014 CAT 299D...
STORAGE FEES (A53426)
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
