Grease Fitting Missing?
   / Grease Fitting Missing? #1
JagAlfaOwner
Bronze Member
Roanoke, Virginia
New Holland TZ24DA
I just put my 60 In Belly mower on my TZ25DA. It had grease fittings on only 2 of 3 the Blade Bearings (directly on the blade spindle). Is it possible mine sheared off somewhere or is this normal? I do not remember last August when I greased it last. Any one checking theirs would be appreciated. There were several on the Deck that I got but I am wondering just about the Spindles as I believe they are the one's most needed.
AL
   / Grease Fitting Missing? #2
I would expect all of the spindles to have grease fittings. I would think you could find it by feeling around. It shouldn't be too hard to remove and replace. You want spindle greased.
Andy
   / Grease Fitting Missing? #3
If they did shear off.. just get a zerk tool.. it usually has a extractor, thread chase, and 2 sizes of wrenches onthe ulti-tool..there is one for sae nd metric.
soundguy
   / Grease Fitting Missing? #4
Not familar with that deck...but some gearbox driven decks have the zerk for the center blade down low, off to the side below the gearbox.
JohnnyB
1998 Blaw-Knox PF 150 Paver (A52384)
1998 Blaw-Knox PF...
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
Case Maxxum 140 (A50120)
Case Maxxum 140...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2011 Liebherr L586 (A53472)
2011 Liebherr L586...
1827 (A51248)
1827 (A51248)
