Gravely Super Convertible Wheel question
   / Gravely Super Convertible Wheel question #1
Tman43
Carrollton
Gravely super convertible
My parts illustration shows that the two halves of the rim are attached directly to each other. But on my tractor the halves on mounted on the both sides of the hub. The inner rim on one side and the outer rim on the other. Which is correct? I am mounting dual wheel adaptors and thought I would replace the tires and tubes at the same time.
   / Gravely Super Convertible Wheel question #2
You should not have to pull the hub to change a tire/wheel assembly. What you describe is crazy. It is difficult enough to get the tires a wheels apart and put back together without having the hub to deal with too.
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
12in x 16.5in Kubota RTV-X1140 Tires (A52377)
12in x 16.5in...
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
