Gravely Super Convertible Wheel question
   / Gravely Super Convertible Wheel question #1
Tman43
Carrollton
Gravely super convertible
My parts illustration shows that the two halves of the rim are attached directly to each other. But on my tractor the halves on mounted on the both sides of the hub. The inner rim on one side and the outer rim on the other. Which is correct? I am mounting dual wheel adaptors and thought I would replace the tires and tubes at the same time.
   / Gravely Super Convertible Wheel question #2
You should not have to pull the hub to change a tire/wheel assembly. What you describe is crazy. It is difficult enough to get the tires a wheels apart and put back together without having the hub to deal with too.
2025 CATERPILLAR 275 SKID STEER (A52705)
2025 CATERPILLAR...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
Toro Mower (A50324)
Toro Mower (A50324)
2015 CHEVROLET SILVERADO 2500HD (A53843)
2015 CHEVROLET...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
