Gravely Pro-Turn 152 Gas coming out of tailpipe
   / Gravely Pro-Turn 152 Gas coming out of tailpipe #1
WVH1977
Platinum Member
Richmond, VA
Massey 2860M Cab, Massey 1E.35, Gravely Pro-Turn 560, 1989 Ford D47 Dump Truck
Hello all,
My zero-turn had a clogged carb due to me not cutting ethanol fuel off last year in the gas tank over winter. This is my fault and I learned a lesson. I pulled the carb off, cleaned it and put back on. It runs fine now but I have to cut the fuel off and run out of fuel everytime now because if not, gas leaks into tailpipe. When I started it again today after using 2 days ago, gas came rolling out of the tailpipe. Still runs like a champ after spitting gas out.
What could be causing this? I am wondering if I put something back wrong or missed something but everything appears to be ok? Maybe I messed up something in the carb when putting back together? Any thoughts from the pro mechanics on here?
Thanks
   / Gravely Pro-Turn 152 Gas coming out of tailpipe #2
Either the carb float is not connected to the fuel inlet needle anymore or is bound up, not letting the float rise to close off the incoming fuel. Or there is damage to the needle or seat.
   / Gravely Pro-Turn 152 Gas coming out of tailpipe #3
Stuck float needle. What I do with my 4 stroke engines to overwinter them is, I drain out all the corn squeezed fuel and add some canned gas like Tru-Fuel which is available with no oil added. Canned fuel has a shelf life of 2 years btw.
Thanks for the responses. will check the float needle again. Trying to avoid buying carb. OEM is 350.00. I have seen cheaper knock-offs but not sure if they are as good. It is a kawasaki engine.
   / Gravely Pro-Turn 152 Gas coming out of tailpipe #5
Have a B&S 20hp mower from 1998. Engine surging and backfiring something awful. Looked at OEM carb, 203.00. Picked up a carb off of Amazon for 30.00. Running better than it has in many years. Like you I was skeptical but decided to give it a try.
   / Gravely Pro-Turn 152 Gas coming out of tailpipe #6
If there's no easy fix, I personally wouldn't hesitate to use an aftermarket carb.
Anecdotal story : wife's Prius needed a new electric water pump. Toyota part is over $400, Amazon generic is $70. Wife wants genuine Toyota pump, which I agree to. Turns out the $70 aftermarket pump has the exact same manufacturer and markings as the Toyota part.
   / Gravely Pro-Turn 152 Gas coming out of tailpipe #7
Since you had gas coming out of the exhaust I would take a smell of the oil to make sure it also doesn't have gas in it. Very common for the gas to also fill the crankcase when the float valve doesn't seal and causing the overfueling issue.
2005 Kobelco 135SR Hydraulic Excavator (A50322)
2005 Kobelco 135SR...
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
John Deere 2020A Progator (RUNS) (A50774)
John Deere 2020A...
2012 Chevrolet Cruze Sedan (A50324)
2012 Chevrolet...
