GRAVELY Kohler KT17 Points Adjustment
/ GRAVELY Kohler KT17 Points Adjustment #1
rusyn
Millstone, NJ
In process
Hello everyone,
I recently own the used Gravely lawn mover which runs on Kohler KT17 motor. When I was cut the grass the deck hit the rock and tractor start to move sporadically. After spending few days figuring out what was a wrong it come up that points plastic body cracked which cause this problem. I did replace the points but could not adjust it correctly. I can set the points at one position that tractor start very easy but will not run good when accelerated to the higher position. Or I can adjust the points to the position when it runs smoothly at the high acceleration but when ignition switch turned off it will not start at all. It seems I can't get the both a good start and a high speed acceleration at the same time. Any suggestion will much appreciated.
/ GRAVELY Kohler KT17 Points Adjustment #2
I would carefully look at the key that is in the flywheel. If it is even slightly wrinkled, it will throw the timing off and cause headaches.
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A65053)
2018 GENIE GTH-636...
12in. Bucket w/ Teeth Excavator Attachment (A64194)
12in. Bucket w/...
IH 1486 Tractor (A66285)
IH 1486 Tractor...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
5' Bush Hog (A62613)
