Gravely dies going uphill
   / Gravely dies going uphill #1
mjfox6
NE Mississippi
2005 Kubota L3400 HST
My Dad has a 12hp Gravely tractor that dies whenever he tries to go uphill or pushes down on the handlebars. He can back up hills and put the tractor under a load without any problems. He's changed points, plugs, plug wires, fuel pump and rebuilt the carburetor, but it still does it. Any ideas? Thanks!
   / Gravely dies going uphill #2
Let me get this right. When you go up hill or push down on the handles, lifting the front end the engine dies. going down hill or on the flats no problem. Sounds like there is something in the gas tank that is covering the outlet when the unit is tilted backwards. I had an old snowblower once that sometimes ran great and other times would be temperamental. I found the cardboard top from a bottle of dry gas. Fixed the problem right up.
   / Gravely dies going uphill #3
I agree with Eric, it is a fuel problem. Either fuel is not getting to the carb or something in carb is assembled wrong. I'd look at the float and float valve very closely.
Thanks fellows!
Float problem it was. The new floats don't work well in the old machines. They had to "re-engineer" it to fit correctly. Wonder if it will last another 35 years!? Thanks again for your help.
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
UNUSED Safety Work Gloves (A53117)
UNUSED Safety Work...
2006 NEW HOLLAND L185 SKID STEER (A52705)
2006 NEW HOLLAND...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55301)
2020 Massey...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
