Gravely 40 inch snowblwer shaft speed [RPM]
   / Gravely 40 inch snowblwer shaft speed [RPM] #1
dave tr
grasshopper 618
Does anybody know the the max impillar shaft RPM for a Gravely snowblower model 05171879. It is a 1991 model with a 40 inch augar. Thanks Dave
   / Gravely 40 inch snowblwer shaft speed [RPM] #2
Hi Dave,
You might try the Yahoo Gravely Group, or just hang out and someone will probably come and answer here.
Oh, you might wanna try oldgravelys.net for many many PDf manuals as well.
   / Gravely 40 inch snowblwer shaft speed [RPM] #3
Gravely PTO speeds are about 900 RPM.
Richard Tx Thanks for your reply to my Gravely RPM. question, Would your answer of 900 RPM. be the normal operating speed? My gear box ratio seems to be aprox. 10-1 That would be a little less than 100 RPM. for the augar speed, does this sound correct to you?
thanks Dave
   / Gravely 40 inch snowblwer shaft speed [RPM] #5
The PTO speed of 900 RPM is at engine rated RPM. The old L models which had a 2400 RPM Gravely engine had different gearing than the later tractors that had Kohler, Briggs, etc which were rated at 3600 RPM. In any case, the PTO RPM stayed the same.
The blower gearing is what it is, so 10:1 seems fine to me.
Be aware that some snow blowers have a bronze gear in them. As such GL4 lubricant is mandatory. GL5 acts more like cutting oil to yellow metal.
2001 CATERPILLAR 908 LOADER (A51406)
2001 CATERPILLAR...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2018 BMW 430I  4DOOR CAR (A54607)
2018 BMW 430I...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
