Gravel too thick?
   / Gravel too thick? #1
lhfarm
Central Indiana
NH TC40DA
After 20 years had to change my "gravel guy." Former guy had a heart attack and had to slow down. He had a single axle truck and, although it took a few trips, could lay down a smooth layer of gravel. My drive is 1400' climbs 250' in elevation and has a couple of turns. After asking around tried a new hauler. Tri-axle trucks and laid down a very heavy layer of gravel. I've had to smooth it every few weeks because delivery trucks "spin out" on the curves and it "wash boards" in sections. Never had to do maintenance this often.
Is it possible to have too much gravel? If so, am I better off leaving it alone and just planning on heavy maintenance or trying to remove the excess.
Thanks,
Barry
   / Gravel too thick? #2
Need to k ow what size the gravel was before we can answer if it was too thick.
A washed, uniform size stone, don't pack and lock in well. So yeah it's possible to be too thick.
Around here we have what we call 304's and 411's. Lots of dust and fines and packs in real tight. That stuff can be applied heavy and packed in for a good base and can even be left at that for final coat. Some call it crusher run, or 3/4" minus or something similar.
A washed uniform sized stone is only good for a top coat. And yeah, easy to spin out on and have a mess if it's too thick.
Limestone vs gravel also makes a big difference.
   / Gravel too thick? #3
Thanks,
Barry
Is it washed gravel, or crushed gravel that you are using?
What screen size?
Loose, washed/crushed gravel will never compact.
You need to buy crushed gravel with some fines included.
   / Gravel too thick? #4
What sort of gravel is it? For example, is it 3/4" crusher? Or clear stone? From my experience if the gravel is round not crushed it won't pack. Crusher run usually packs down fairly quickly but maybe your hill is the issue. My parents had a 1500 foot lane and the crusher run was probably 6 inches thick and we didn't really have any issues (but it was flat). I'm sure there are more knowledgeable TBN'ers than me though.
   / Gravel too thick? #5
It sounds like you have wrong gravel
Crushed gravel locks together better than most natural gravel
Is gravel uniform in size. To pack tight, gravel must vary in size
   / Gravel too thick? #6
If you do have the washed rock with no fines in it then you can probably topcoat what you have with some fines or chips. Drag your shallow set box blade teeth thru it to mix it up. Should help solve some of your issues.
   / Gravel too thick? #7
Even with crusher run on a steep driveway it needs to be well packed before any delivery trucks or heavy stuff comes up it, if it's loose at all it will rut and washboard. Moisten and pack - more than once!
   / Gravel too thick?
I looked at the invoice and there is no indication of the type of gravel. I know that most of the drive had crusher run (plenty of fines) and that section (about 3/4 of the drive including a 90 degree turn) is doing fine. Near the top of the hill by the house, a different gravel was spread. It might have been "washed" as it is smaller and has a more "finished" look. I've never paid attention to gravel size/type since my guy always did a good job. The drive was put in over 60 years ago, so the base is solid.
I used a rake to crown the gravel and left it piled in the center. We are expecting rain the next couple of days and I'll see how this works.
Thanks for all the advice.
   / Gravel too thick? #9
I don't know the names of the gravel but it's possible that he used rounded gravel as opposed to crushed that has irregular edges. On rounded stone/gravel drives I have seen the gravel slide all over the place.
   / Gravel too thick? #10
Crusher run pack well should take care of your problem...don't forget to crown it.
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
2021 CATERPILLAR 279D3 SKID STEER (A51242)
2021 CATERPILLAR...
(5) Rolls of Barb Wire (A50515)
(5) Rolls of Barb...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
UNUSED FUTURE 3T HYD THUMB CLAMP (A51244)
UNUSED FUTURE 3T...
