Grate for Drainage Pipe Inlet?
   / Grate for Drainage Pipe Inlet? #1
mroberts5
Bucks County, PA
Ford/NH 1920
My property and a neighbors has a series of swales/ditches that lead to a pooling area before entering 100ft or so 15" clay pipe. This has been clogged up since I moved in 5 years ago and I finally dug it out today. I found a section of cinder block had made its way in and allowed it to clog up (much of the drainage area runs through woods so there is a heavy load of leaf and stick debris passing with the water).
I'm thinking about how to prevent this from happening again and am batting around a few options - I wanted to see if anyone here has any ideas:
1. Leave it open, minimizing the chance of nuisance clogs at the inlet, but need to inspect regularly for anything large.
2. Add a inlet beehive style grate - I'm thinking this will clog up with leaves right away.
3. Add a very course grate, maybe just two lengths of rebar hammered in, just to block anything large enough that will clog.
At this point I'm leaning towards option 3. Any other ideas/suggestions?
Thanks,
Matt
   / Grate for Drainage Pipe Inlet? #2
A picture or so would have been highly useful.
   / Grate for Drainage Pipe Inlet? #4
Maybe option 3 but option 2 sucks. I see a lot of pipes with a way too fine grate that plugs up and ends up washing the pipe out. Unless the pipe is too small chances are it won’t plug up anyway.
   / Grate for Drainage Pipe Inlet? #5
In a situation, such as yours, I would pound in the rebar( option #3) and check frequently. You will soon find the necessary frequency of checking required to keep it open and running. Any "mesh type" grating will plug and cause problems.
The neighbor and I made a removable rebar grating for his driveway culvert. Two three foot chunks of treated 4"x4" post. Drilled holes in each post every 6". Heavy 1" rebar - cut and pounded into the posts. Ended up with a grate 3' x 3' with 1" vertical rebar every 6". This home made "grate" is all tied together with 1" x 4" x 3' treated boards that form up the ends of the grate. He lifts it out with a chain & his FEL on his tractor. Cleans it in the spring & fall.
Wish I had a picture but........ The grate top and bottom are the 4"x4"x3' chunks of post. The sides are the 1"x4"x3' treated boards. The rebar is pounded into the drilled holes in the top/bottom post material. It ends up being a fairly heavy unit. He can either tip it forward and do any cleaning or completely lift it out with the tractor, chain & FEL for major cleaning.
   / Grate for Drainage Pipe Inlet? #6
I have a culvert thru a wooded area, 30 inch concrete, it plugs, and my gravel driveway washes out. There's a lot of ideas on Google Images under "culvert grates".
This month it started to rain hard as I was crossing it and I checked for the usual debris and it looked OK. Back home an hour later and it was plugged-gravel drive was washed out. Digging it out later, a heavy stick had washed down sideways and was spanning the opening. Smaller sticks and leaves are then blocked by the stick. It's happened like that 3 or 4 times. So in my case, periodic preventative cleaning won't solve the gully washers.
I like this concept of slat arrangement (although their cement housing is overkill for mine) Those sticks that are just the right size to block things either get captured or turned. The angle slats might force sideways sticks upward and there's more area for flow. I think a smooth slat would be better for this angled design than rebar.
Thanks for the feedback so far. Here are some photos. I said clogged before, but actually it was buried. My plan is to dig it out further then build a stone headwall, similar to what jmc attached, but...stone. Also, you can see from the outlet that its been eroding back real bad. I'm not sure yet if I'll try to reset the last few peices or just accept it how it is, but I'm going to build an endwall with a stone apron and gravel/boulder bed to help dissipate the energy. Or at least thats the plan....
Inlet: It was really hard to capture this in photo, but its a 15" inlet that was buried in mud
Outlet:
   / Grate for Drainage Pipe Inlet? #8
Put your grate 3 or 4' before the culvert so it it plugs when your not around the water can get around it but the pipe won't get plugged up.
   / Grate for Drainage Pipe Inlet? #9
Outlet:
that first picture looks like big foots hand print on that tree :D I like JMC idea or something similar
   / Grate for Drainage Pipe Inlet? #10
After seeing your photos Id just clean up all around the opening and leave it open. Expose the ends of the pipe and don稚 allow overhangs of soil, plants, roots etc. It looks like it gets seasonal use only so I wouldnt bother with a grate as you will end up having to clean that too after it gets overgrown with grass etc.
If its open you can easily get at it with a backhoe. Grates have to be cleaned by hand.
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
Hustler Raptor Zero Turn Mower (A53117)
Hustler Raptor...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
