grassing ditch and strip
   / grassing ditch and strip #1
laurencen
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
Hi, need some advice on my new road and airstrip, sorry the pictures are still on site, will add later, The last 2 weeks had a new driveway to our house aprox 1000 feet, it is crowned with ditches each side, the drive is 24 feet wide, ditches are 30 feet wide, also added a airstrip 1800 foot long and 60 feet wide, at this time no weeds but want to grass them, what is the best mix, my location is Saskatchewan Canada, I plan on using the drag behind the tractor to smoothe it out, after spreading the seed should it be dragged again, I will be dragging with a diamond shape steel device that has teeth under it, not sure the name, found lots of them in the bush
Thanks in advance
Laurence
   / grassing ditch and strip #2
I am not sure I understand what your question is...
David from jax
   / grassing ditch and strip #3
I would believe those are as we called them "Diamond Harrows". :D
You may want to check in with your local seed supplier to find which grasses
would be most suitable for your application. I'd assume it would be a type of high usage lawn mix as again I'd assume you will keep it mowed.:confused: :confused:
Spread your seed, harrow and then hope for some nice planting rain and warm sprouting weather.:D
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
TIRE TOOLS, BUNGIE CORDS, BALL HITCH (A53843)
TIRE TOOLS, BUNGIE...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
