Comparison Grasshopper vs Ferris vs John Deere vs Snapper
   / Grasshopper vs Ferris vs John Deere vs Snapper
Thank you all for the reply
are the machine frount-mount more difficult to drive?
   / Grasshopper vs Ferris vs John Deere vs Snapper #13
No, they're not. The deck is out in front of you so it's easier to see what your cutting, especially when you're trimming next to a fence or going around a tree.
The front mount mowers are longer and the tail wheels stick out the back, so you have to remember that when you're turning next to a fence or building. If you turn too sharp you can swing those tail wheels into the fence or building. But you get used to it pretty quickly.
   / Grasshopper vs Ferris vs John Deere vs Snapper #14
One of the things to note about a grasshoper front mount . . Especially if you get power lift . . . is hwyou can acess the blades for easy maintenance AND tilt the deck for trimming and tree/fence/culvert access for cutting.
But stability on slopes with a front mount is good. Deck is in front, rear trailing wheels are behind, and you and engine and drive wheels are all in the middle. Normal zero turns are drive wheels and rngine in rear. Grasshoppers combo gives you better leverage on slopes and spinn from center means easier on turf and better slope stability. And if you have a snow situation . . What a snowblowing machine. If you see a front mount with a snowblower attached . . you'll instantly see why.
I saw that in the side slopes, the mid-mount tends to slide sideways
with the front-mount I have the same problem of slippage?
example Grasshopper 428-61R - YouTube
   / Grasshopper vs Ferris vs John Deere vs Snapper #16
Are these units built for the kind of mowing/brush cutting shown in that video?
I've got similar terrain, roughness, and brush I'd like to get cleaned up and mow a few times a year. It's under trees and on slopes so tractor with brush hog is difficult and slow. I've been watching for a ventrac or steiner with a rough cut mower, but if a zero-turn could handle this occasionally, they seem to be more available and that would be nice to know.
   / Grasshopper vs Ferris vs John Deere vs Snapper #17
I watched the video you linked to showing a mid mount grasshopper attemoting to be a bush hog of branches and small tree stumps. That mower is not a front mount as I have discussed and that land is not a yard or lawn or even pasture. Its not even suitable for a rear finish mower.
A mid mount grasshopper is a world of geometry apart from a front mount grasshopper.. a front mount has the weigjt in the center and a mid mount has the weight in the rear. Its a world of difference
   / Grasshopper vs Ferris vs John Deere vs Snapper #18
The machine in the video is a 428D with the Kubota diesel engine. It's a great machine that probably costs $13,000 - $14,000 these days. I would be proud to own one, but I'd sure take better care of it than the guy in that video.
As AxleHub said, they are tough, dependable machines, but they are not designed to replace a brush hog. Mowing over large branches and small trees is abusive.
the seller offered me a grasshopper mod. 620 frount-mount with 780h worked, are too many?
   / Grasshopper vs Ferris vs John Deere vs Snapper #20
In the world of Grasshopper . . Users talk in 1000s (with an S) of hours. Espevially in front mount units in lawn care businesses . . We're talking 3000 and 4000 hour benchmsrking . . .
MASSAGE CHAIR (A58214)
Husqvarna 42in Riding Mower (A56859)
Husqvarna 42in...
2003 KOBELCO SK235SRLC EXCAVATOR (A57880)
2003 KOBELCO...
2021 Bobcat E42 (A53317)
2021 Bobcat E42...
(3) Goodyear 480/80R38 Tires (A56469)
(3) Goodyear...
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
