Grasshopper Fertilizer on Wheat
   / Grasshopper Fertilizer on Wheat #1
bumpercrop
Has anyone used Grasshopper liquid fertilizer on wheat?
This is somewhat of a follow up to:
"fertilizer question" on 4/21/08
[I have 12 acres of Giant bermuda hayfields and 10 acres of Alfalfa here in hot and dry West Texas. I have to irrigate all the time which is no big deal and I don't mind paying for that but fertilizer prices have gotten way out of hand this year so I began looking for another company to buy from.]
Response:
[I read this thread earlier this summer regarding Grasshopper fertilizer and became interested. I later had it recommended to me by an Ag Teacher in East TX. Since then I have used it on a few fields.
I have used ammonium nitrate for decades and have also tried a number of liquid blends. Grasshopper seemed appealing because you will absorb and use 100% rather than the 20% with traditional fertilizers. A fertilizer that can be absorbed without rain and could be mixed with herbicide seemed worth a try.
The actual weight of the dry mix per acre was 12-13 lbs. It seemed light at first compared to 250lbs of dry commercial fertilizer. Then again, this 12-13lbs was going directly into my grass vs the 250lbs of commercial going into my soil. I was advised that applying more at one time would burn my grass. The grass greened up within 2 days and within 21 days - I was cutting hay. I have since used it on Coastal Bermuda, Bahai, and mixed grass pastures.
My horse hay has maintained its quality 17-18%. Although I have not yet tested my soil to see its effect. From what I understand, soil should maintain its mineral levels. With grass being fed directly with a foliar fertilizer, less nutritional demand is placed on the soil.
It may not be as stout as Ammonium Nitrate - but this year I will be able to sell my hay for less and have a larger profit margin.]
Just a follow up:
I tested my soil after using Grasshopper Liquid Fertilizer last year. My soil has maintained it's mineral levels. In fact, some pastures I sprayed had a slightly higher amount of N.
I also sprayed 50 ac of wheat last week with their 30-10-10.
Back in Feb I sprayed some wheat with Grasshopper Liquid Fertilizer. I took some pics and collected some data but have been too busy to get back to this discussion board until now.
I have attached a 'with' and 'without' picture to this post. I have not attached pics before so I hope this works.
The 50 acre plot with Grasshopper had a significant improvement in color, thickness and height (6"-8" difference).
The remaining acreage was not sprayed at all. I usually apply UAN on my wheat which may have performed equally. However, I did not receive any rain until 12 days after this application. I believe the UAN would have produced less improvement under these conditions.
My original intent was to compare a section to UAN and nothing at all. But after the results on these 50 acres, I sprayed the entire field. We yielded 41 bpa which is good for our area. We are usually in the 30-35 range.
Since this application the cost difference between Grasshopper and UAN has narrowed, but I still have a higher margin with Grasshopper.
2025 CFG Industrial MX20R (A50123)
2025 CFG...
Concrete Mixer Mini Skid Steer Attachment (A51691)
Concrete Mixer...
Toro Mower (A50324)
Toro Mower (A50324)
2020 CANYCOM SC75 STAND ON DUMP BUGGY (A51246)
2020 CANYCOM SC75...
CFG Industrial SAII100 (A50123)
CFG Industrial...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
