Grasshopper 900D Grease zerk locations
/ Grasshopper 900D Grease zerk locations #1
sawtooth
Veteran Member
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
Anyone know where and how to get to the front zero on the clutch power shaft? I found the one at the rear of the mower on a pillar block bearing but can’t see the front one. I did find the one under my feet on the universal half shaft though. Any help would be greatly appreciated. Thanks.
/ Grasshopper 900D Grease zerk locations #2
The front one is pretty much exactly like the rear. You found the one on the half shaft, so look further behind that, and find the pillow block that the bearing sets in, and then look around till you find the grease zerk, on my 725, its on the right hand side (right hand side if you were sitting on the seat). It's tucked in there in a somewhat difficult place, but not impossible to find.
/ Grasshopper 900D Grease zerk locations #3
On my 725DT6 it's on the right/passenger side, where as on the new 900 it is on the right side, as I remember it
