grasshopper 321d
   / grasshopper 321d #1
banshee.350
florida
new holland tc30 4x4, grasshopper 321D
I just bought a used grasshopper 321d midmount. I am about to change all the fluids and I read in the manual to only use grasshopper brand hydraulic fluid . This fluid is $15/quart and it takes 5 quarts ($95)! Is it really necessary to only use grasshopper brand hydraulic fluid? If it is I would rather spend the $95 than have to replace a hydraulic pump in the future. Any information is greatly appreciated. Also if anyone knows a good place for new or used parts for the grasshoppers that would also help.
   / grasshopper 321d #2
Try here for parts. The Mower Shop, Inc. - Home Page
I don't know on the hydro oil since I haven't changed mine yet (322D) but like you said 95.00 is cheaper than a motor.
   / grasshopper 321d #3
I used to have a Grasshopper 616. I went through the same thing. I recall that either the book or the dealer said that you could use some kind of Mobil One synthetic in place of the Grasshopper oil. Problem was, there wasn't anybody around that had that, so I ended up buying some of the Grasshopper stuff from the dealer. Luckily, in my case, it was just a little low, so I just bought one quart.
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2014 Rockwood Premier 2317G 23FT S/A Pop Up Camper (A51694)
2014 Rockwood...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
2003 500 BBL FRAC TANK (A53843)
2003 500 BBL FRAC...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
