Mowing Grass sticking to bottom of mower deck
   / Grass sticking to bottom of mower deck #11
Von
I am no expert, but look at those blades. talk about nicks. This could be part of your problem. Your mulchin the grass not cutting it. This would create more moisture and more build up under the deck and that picture shows you have a build up problem.
I get that problem but only when I cut when the grass is wet.
Clean it up and make those blades razor sharp let the grass dry and give it a try.
On the hi-vac blades I have used them on my JD 316 with a 40" mmm. There is one problem with them they tend to make a lot of dust when it is realy dry.
good Luck
Winnipeg, Manitoba
2001 BX2200 All Kubota FEL, Tiller, box blade, blower w/elec shute, 60 mid mt deck, Ag tires.
Grey market B7000 w/Tiller (120 hrs)
1984 JD 316 after 687 hrs.
   / Grass sticking to bottom of mower deck #12
2016 Chevy caprice (A55788)
2016 Chevy caprice...
2013 Ford Edge (A54815)
2013 Ford Edge...
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
