Grass Pit
/ Grass Pit
To finish off the sections i put up two moveable timber containing walls. This means that the waste can be built up and left for about 6 months before spreading on the veg or roses in the garden
/ Grass Pit
view from the front
/ Grass Pit
first cut of grass in pit. It works very well and leaves emptying the bag very easy. Just have to be careful that u dont back too hard against the wheel stop or u could end up becoming compost yourself. Im pretty happy with the way things have gone and the whole experience has been very worthwhile. A neighbour is asking if ill build him one. Total cost was about 230 euro which aint too bad. Next project is the workshop so ill try get a post about that going. Cheers for your opinions anyway its nice that somebody thinks its good.
/ Grass Pit #24
Thanks for sharing. It's an interesting aproach and technique. I kept wondering what your stores are like for buying lumber and material. Do you have a Home Depot type of place?
Eddie
/ Grass Pit #25
"i a going to try and make good compost with it "
For composting.. you need air.. and the compost is turned over at regular intervals to get air into the pile for the microbes.
"Composting microbes are aerobic -- they can't do their work well unless they are provided with air. Without air, anaerobic (non-air needing) microbes take over the pile. They do cause slow decomposition, but tend to smell like putrefying garbage!"
http://vegweb.com/composting/how-to.shtml
I'm afraid your grass pit will fill w/ water and you'll end up w/ a slimmy green yuck.
All said.. it is a nice pit.
Edit: After looking again.. will your FEL fit between the block walls to turn the pile.. w/ the one side open it could work pretty good.
/ Grass Pit
well i plan to build a cover for it to prevent it filling up with water. Im also going to get a load of tiger worms from my neighbour and hope they will chaw up most of it. Sure if it dont work it dont work. God loves a trier..
/ Grass Pit #27
Nice work, great position so you cant see it from the house. Looks like you got the tools too! /forums/images/graemlins/smirk.gif
Mine is cut into the side of a slope so you dump at the top on ground level and epth at the bottom at ground level.
Are you planning to put organic waste in there too? If so it should compost well on its own with the worms.
Eddie, here in the UK we have B&Q and Homebase, which is the general place to buy DIY and gardening stuff. There are also specialist shops, like TP which sell stuff for the trade, hire equipment ect. Though I dont know I presume it is simalar in Ireland.
/ Grass Pit
Mith,
Any chance of a few pics of your compost heap. Yea all kitchen waste is going in too so hopefully it will work. A relative has done the same job and he mulches any tree cuttings and anything big so that it composts better. the compost he makes is like black gold. B&Q and the likes are all here as well as smaller local diy shops.
Cheers.
/ Grass Pit #30
Well I wont pretend its as nice as yours but like most of my things it does the job and looks, well, kinda dont exist. Dug it with a digger and made it from pallets and baler twine. The far left bin is ready, the other two are overflowing. Ought to empty the first bin really. Maybe next month.......
/ Grass Pit #31
Excellent project for composting, however I tackled it in a slightly different manner:- I went out and bought a B7100 with a front loader!! /forums/images/graemlins/grin.gif, now when I want to pile up the cuttings I play on the tractor for about few minutes and just heap it up. It is also easier to dig out the heap with a FEL . At the end of the year I turn the first heap into a second heap which rots down over the next year ready to spread around the garden and remake the first heap with the new cuttings. Altogether more fun I can assure you and a good excuse to buy a tractor with FEL attached!
/ Grass Pit #32
Even without a FEL, I suspect you could turn the pile a bit with a pitchfork, just working from the side openings.
But all in all, it certainly is a high digit effort. And now you're adding a roof? With just a bit more work you could probably add an enclosure with an electric hook-up. Then get a TV, fridge, recliner lounger -- and you'd have your very own grass pit retreat. /forums/images/graemlins/smile.gif Just don't tell the wife what you're up to. /forums/images/graemlins/wink.gif
Cattle Feeder (A65640)
2014 Freightliner 114SD Grapple Truck, VIN # 1FVHG3DV2EHFV3934 (A65563)
2014 Freightliner...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
17.5X25 industrial tire on Deere articulated loader rim, Coal Valley, IL (A65640)
17.5X25 industrial...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
Wood Fence Post (A62613)
Wood Fence Post...
