Grass Catcher # for 1864 w/ 46" Deck
   / Grass Catcher # for 1864 w/ 46" Deck #1
kruss77
Fenton, MI
1995 CC 1864 Hydro
Does anyone know the original CC part number for the triple bag grass catcher for the model 1864 garden tractor with a 46" mower deck?
   / Grass Catcher # for 1864 w/ 46" Deck #2
The only number I found was 190-293-100. It is a fan assisted bagger. For the 1862 I found 190-335-100 was a triple bagger for a 46" deck.
   / Grass Catcher # for 1864 w/ 46" Deck #3
check out the cub cadet website under parts. its an easy lookup.
After not finding ANY grass catchers for the 1864 model listed on the CC website, I too checked out the 1862 section and found p/n: 190-335-100, but I'm not 100% sure that that was the original part number that matches the original triple bagger I've got (the model sticker on my grass catcher is LONG GONE and there are no other numbers listed anywhere on it). I suppose it doesn't really matter since the 1862 and 1862 are for-all-intents-and-purposes the same machine as far as most accessories are concerned. I was looking for the grass catcher chute so that I could adapt my existing mower deck boot to the pickup hose on the Trac Vac I just bought. The factory CC grass catcher deck boot is FAR superior to ANYTHING else out there in the aftermarket. But I need to go from an 8" mower deck discharge diameter down to a 6" pickup hose diameter on the Trac Vac. To accomplish that I was going to buy a new factory CC chute and taper it down gradually from one end to the other (8" at the deck boot down to 6" at the Trac Vac pickup hose) over it's full length. That way I could minimize/eliminate the potential for clogging vs. using the short 8"-to-6" reducer/adapter available through Trac Vac. That's the idea anyway.
   / Grass Catcher # for 1864 w/ 46" Deck #5
The part number for the discharge chute is(item #1) 731-0925C and the elbow(item #2) is 731-0926B.
Thanks for the help. Here's the finished project.
The finished setup worked-out better than I had hoped and made the process of fall cleanup VASTLY more efficient. I went from 6 hours using a rake and leaf blower down to 2 hours with the powered leaf vac and remote suction hose extension for clearing-out the landscape beds!
2006 Toyota Prius (A56859)
2006 Toyota Prius...
2016 CATERPILLAR 262D SKID STEER (A52709)
2016 CATERPILLAR...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Service Truck (A55973)
2015 Ford F-350...
YAMAHA OUTBOARD MOTOR (A58374)
YAMAHA OUTBOARD...
2015 International Durastar 4300 SBA 4 x 2 Water Truck, VIN: 3HAMMMMN4FL510006, Cummins Turbo Die... (A59076)
2015 International...
2018 Dodge Ram 3500 (A57148)
2018 Dodge Ram...
