jedolson
Field is tall but I've got the cutter at the right height. Pulling 5' cutter with 9N. **** grass winds around the PTO shaft and builds up and causes strain on system. Is there a simple solution to this that I am overlooking?
			jedolson said:Yes I have a shield on it but it rotates with the pto...not sure I can get it loose but I'll have to try and then chain it down....another shield up near the pto at the tractor that bolts to the tractor would also help I guess.
To the guy who suggested the knife to cut it away with, you win the prize! and the prize is, you get an all expense trip to my 20 acres to ride back on and straddleing the cutter and hold the knife down on the pto shaft every time the grass starts to build up.
