Grapple will open, but will not close however, it works manually when depressing at the end of the spools
   / Grapple will open, but will not close however, it works manually when depressing at the end of the spools #1
Nb707
Bronze Member
2020 kioti 4710 se hst cab
Spending hours on this trying to figure this thing out. This is a difficult one. Called wr long talk to them about the issue after doing some troubleshooting they sent me out a new rocker switch and control module thinking it’s electrical problem. The rocker switch is fine. Switched out the control module same issue. I’m scratching my head. I can’t figure this out. I operated it manually and it worked anyways. RW long is sending me another control module. This hopefully will take care of it.
   / Grapple will open, but will not close however, it works manually when depressing at the end of the spools #2
What happens if you swap the hydraulic hoses? Will it close then?
   / Grapple will open, but will not close however, it works manually when depressing at the end of the spools #3
"but will not close when I depress the solenoids manually." Heres the clue. It appears that the solenoid doesn't open even when activated. Like said above switch the hoses. If it then opens replace the solenoid.
   / Grapple will open, but will not close however, it works manually when depressing at the end of the spools #4
My dual lid grapple usually opens or closes one lid sooner or faster than the other. It's normal and expected with parallel cylinders on the same circuit. Tiny differences in friction make the difference.
"but will not close when I depress the solenoids manually." Heres the clue. It appears that the solenoid doesn't open even when activated. Like said above switch the hoses. If it then opens replace the solenoid.when I depress the solenoid manually. It opens and closes.
Thank you for help. I greatly appreciate it. However, perhaps you miss read my post. When I depress it manually The solenoid grapple works. It closes and opens.
   / Grapple will open, but will not close however, it works manually when depressing at the end of the spools #7
Have you checked to see if you are getting 12 volts at the valve when the switch is pressed?
If you are and it still doesn't work check the resistance of the coils on the valve. They should be the same resistance. Why does a grapple need a circuit board?
Spoke with WR long tech-support they’re really good guys. Turns out it was the control module they sent me was faulty. They’re sending me out a new one that should take care of it.
Thank you, but it had nothing to do with the hoses and operated manually. It’s an electrical issue.
   / Grapple will open, but will not close however, it works manually when depressing at the end of the spools #10
Spoke with WR long tech-support they’re really good guys.....
I lost a pin to their Bolt on grapple, I was able to stop by their manufacturing place in Tarboro and the owner looked up the plans to find the correct pin size and we walked into the shop and he handed me the pin. I tried to give him $10 but he wouldn't take it... very nice guy.
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
2014 Dodge 5500 4X4 Bucket Truck (A51039)
2014 Dodge 5500...
2011 DODGE RAM 2500 (A50854)
2011 DODGE RAM...
Unused 2025 CFG MY50R Mini Excavator (A49461)
Unused 2025 CFG...
