Grapple vs forks
   / Grapple vs forks #21
Forks can't do this...
Sure they can, you slide them right under the stone and lift it! I've done hundreds of them with mine.
SR
   / Grapple vs forks
I am half a step ahead of you. A have a small heavily wooded acreage and now have a used tractor with limited budget for attachments. I have been told that once I own a set of forks that everything will go on pallets -buckets of sand, firewood, other attachments and logs. I like the idea of easily moving stuff around.
Moving brush will only be occasional over the long run and can either load in my utility trailer or I might consider the grapple attachment for the forks.
HLA Attachments - Single Arm Log Grapple
I expect a grapple for see little use after the first major cleanup. That said there are some compelling arguements above. If only a neighbour had a set to borrow/rent.
Peter
This is kinda my thought process too. Once I get the initial clean up done there really shouldn't be a lot of brush moving. If I got a tooth bar for the bucket it would be enough to move the brush around. And i think the pallet forks would be ok to move any logs I need to.
   / Grapple vs forks
I use the grapple far more than my forks for brush/tree clean up. Not sure on your tractor size your considering but I just have a 48" single cylinder grapple from carolina attachments. Cost was only $900 and it's built here in the USA and seems to be built pretty stout. I spent about $1700 total for grapple and 3rd function. Great for brush and logs. View attachment 585859View attachment 585860
That wouldn't be such a bad option. Alot better than some of the prices I've been seeing for 3rd function install and the cost of the grapple. Every dealer I've talked to charges right around $800-1000 for the install. Then I had only found grapples in the $2000-2500 range. But guess it really depends on the tractor I decide to go with.
   / Grapple vs forks #24
TIf I got a tooth bar for the bucket it would be enough to move the brush around.
I have a Pirhana tooth bar. It's no good for moving brush. Maybe it'd help a little if your brush is small and mostly fits in the bucket- the tooth bar sticks out another 3" and gives a slightly larger surface for things to sit on. But my brush is large and won't fit in the bucket. I've got 20 acres half in very thick brush and half in thick forest.
I also have a grapple and pallet forks. The grapple is the implement that stays on the tractor. I use it a lot for moving brush and logs. With the grapple I can grab the end of a log and drag it out to where I can get at it from the side. That's faster than chaining up the log and pulling it.
I use the pallet forks for pallets and IBC totes full of firewood.
   / Grapple vs forks #25
A tooth bar is useless for carrying brush but great for raking up small brush.
   / Grapple vs forks #26
SR
lol, there was no "sliding" except the tractor "sliding" backwards down the hill. That rock was plucked out of the ground.
   / Grapple vs forks #27
You mean like this one?
OR something a little bigger like this one?
I've taken many loads of them out with pallet forks,
SR
   / Grapple vs forks #28
I've removed plenty of rocks the same way with no thumb attachment. I would like to add one it would help out with the brush pile and log piles.
   / Grapple vs forks #29
What's really nice about pallet forks with log piles is, they are long and allow you to dig through the pile and pick logs out of the bottom or where ever, without having to move every log. I love the way I can select certain logs out of a pile for my BSM!
Another thing, they make a perfect table with a piece of wood across them! I use them for a big flat table all the time, that's adjustable for height!
SR
   / Grapple vs forks #30
Each have things they excel at. If you check back several messages in this thread, you'll see I was the one that recommended the thumb/grapple attachment for pallet forks as a makeshift grapple. It increases the utility of the forks. There are still things a grapple does do better.
Digging rocks up with forks is doable, but not ideal. Most manuals recommend against digging with forks due to the increased leverage on the loader. Digging small roots out is impossible. The distance from the loader pins on the clamping point of those forks reduces the overall lift capacity for moving real materials.
There is no silver bullet tool that is ideal for all uses. Most folks will make do with what they have available and do fine. If you have needs a grapple is ideal for, it is the fastest and safest solution there is.
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
406 (A52706)
406 (A52706)
Hays LT-1 Tender (A56435)
Hays LT-1 Tender...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
