Grapple,Scrap metal and etc.
   / Grapple,Scrap metal and etc. #1
sanman
North Louisiana
kubota L3130
You folks on TBN has helped me so much,and I'am posting a few pictures to show what I've done with all this info and maybe give somebody else some ideas.
This is a belly pan that I made from scrap that was design to be fairly easy to install/unstall because I did't want any drain holes to maybe grab a snag an maybe go inside an do some damage
This is my right side step. that is real handy if you know what I mean. Just to the right is simple pipe plug that hold short pieces of chains inside.
Rear remotes with hydraulic toplink.
Had to buy a little metal here but even a cheapscape like me has to breakdown every now an again
Valve setup
I found a piece of 1/2" metal conduit laying around an brazed apiece of tubing on the side that was big enough to fit my switch,cut a slot underneath,closed an drilled the other end,put set screws in the tubing ,removed the joystick ball an slipped tubing down stick an tighen screws.
Finally,
another switch view with remote valve in back. The valve is mounted inside a box made from two pieces of u-channel {you
guessed it} [scrap] an mounted to the ROP with u-bolts.
I almost forget!
The toothbar in 4th picture,I found it at [partboys.com or maybe partsboys.com] @ 40% off [heavy duty]. Cost me $195 plus $80 shipping.
I hope this info an pic will help.
I think you all.
   / Grapple,Scrap metal and etc. #8
wow really nice work! ever color coded /forums/images/graemlins/wink.gif though I don't own anything THAT color it is very nice one though. anyhow good job on the idea for the diverter switch location right on the joystick. no fumbeling there! /forums/images/graemlins/wink.gif
Mark M
   / Grapple,Scrap metal and etc. #9
Slick looking set up, especially the grapple. The belly pan is nice also. I do a lot of slash and log retrieval for fire mitigation and use a Power Trac which has a slick belly and it just slides off of stuff that would have snagged or damaged my regular NH tractor. Nice work!
Oh!
Cost wise,I;ve spent about 14-$1500 out of pocket for everything.
72In FEL HD Round Back Bucket (A52748)
72In FEL HD Round...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
2012 Nissan Rogue SUV (A50324)
2012 Nissan Rogue...
Toro Mower (A50324)
Toro Mower (A50324)
2019 Dodge Journey Crossroad SUV (A50324)
2019 Dodge Journey...
