dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,565
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
Bottom line is that some gap is desirable and I'd imagine a minimum of 1/4 inch or so. Again, the key issue is how far the retaining pins protrude from under the mount when locked.
The folks at Gator were concerned that my gap was 5/16-3/8". They sent me 1/4" shims as they said no more than ~1/8" is acceptable. I agree. It fits much better after I did that, but then the upper hook design was still an issue that I fixed later on. It did slightly bend the original lower attachment hook when it popped out the first time or two, so yes, I would say having it loose on the mounts does add additional stress as it is applying stress out of position vs the design intent.
Based on what I was told and saw, I would put 1/4" at the upper limit.
Yes that would put strain on the pins. Typically though we tend to lift and curl more than pull directly backwards. Again, with appropriate length pins it wouldn't matter.
I often find with solo logs I have to lift them straight up with the grapple in full dump, otherwise I end up scooting them along the ground forever without anything to stop them, and with my hilly terrain, I don't have a lot of ability to change positions or I get pretty tippy going cross-hill.
