Grapple rake for the 422/425?
   / Grapple rake for the 422/425? #21
Grapple
Anyone know anything about these. Lot cheaper than ANBO or Long, but no clue as to quality. (I'll cross post in attachments forum.)
Charlie:
it is a VersaTech brand grapple and it is 66" and weighs 500 lbs.
The guy's name is Dave and they buy them and resell out of a warehouse in upper NY state.
His number is (315) 247-3731.
I asked him about a 48" version, but we got cut off as his cell was not getting good reception.
If you look at the pic, the ends could virtually be cut off making the bucket approx. 52" wide. This would be better for us 425 users and would probably save a little weight too. Something in the 400 lb range would be good.
   / Grapple rake for the 422/425? #23
<font color="red">VersaTech brand grapple and it is 66" and weighs 500 lbs. </font>
It's the size and weight I'm looking for. It clearly wouldn't be as strong as the W.R. Long or Anbo, but maybe can take all our hydraulics apply.
Tempting. I'll have to consult Bubenberg.
/forums/images/graemlins/grin.gif
True, but I would think that it would be plenty strong enough for a 425??
   / Grapple rake for the 422/425? #25
JJ, I agree with you in pricipal, but Charlie and I have the same machine and there are no alternate holes in any of our linkage. I did look hard and long at an easier solution than cutting my fork lift apart and redoing it, but I ran into mechanical interference and/or motion loss in other positions that was not worth it for me.
The PT lift arm geometry is less than ideal, at least on the 1845, but is ok if most all attachments utilize a nominal 30 degree forward tilt of the QA plate. I have not noticed adjustable linkage on any of the current models, is yours an older one? If so, perhaps it is a feature they should have kept.
   / Grapple rake for the 422/425? #26
Yes, my Pt-1445 is a mid 90's model. You can take a piece of 3/4 thick, say 2 by 24 in, and put 3/4 holes where ever you choose.
To determine the length and holes, remove the pin from the tilt arm and raise the lift arms, if you want the forks to point straight down, measure the distance required for that setup. For max tilt up, lift the implement if you can, or support the implement to give a max tilt up, and measure. You may have to make two tilt arms for different implement, with different sets of holes.
   / Grapple rake for the 422/425? #27
Rip:
As I look at various root rakes, I've concluded that the first thing to do is make a PT to universal skid steer adapter, with a 20 or 30 degree tilt built in. I suspect it won't add too much more weight than welding and gusseting a PT plate to the rake itself. I'm leaning toward the Versa-Tech, which is light, but haven't yet ruled out W.R. Long or Anbo. As usual, the search process is probably the most fun I'll have with the implement. /forums/images/graemlins/tongue.gif
I hear ya, searching is fun Charlie.
Making the skid steer attachment sound like a great idea. I wonder what the weight difference will be?
   / Grapple rake for the 422/425? #29
Someone on the forum has already welded up an attaching plate for the Quick-Attach. It was for a 1445.
   / Grapple rake for the 422/425? #30
JJ, The adjustable tilt link sounds like a good idea.... I gather yours came that way? Back in the 90's, wasn't the Quick Attach an option rather than standard?
I guess they opted for one compromise length when they made the QA standard to let you swap back and forth with any attachment without having to reset the link pin. The key word here is compromise. If you only use PT attachments it is no problem, and really is no big deal if you take their geometry into full consideration when setting up anything else.
When I said I could not find an easier solution, I was looking for a modification that would still work with anything else. In any case the deed is done and the forks work fine with the plate at about 30 degree tilt. Just does not look as pretty as it did the first time.
Charlie, If you have your eye on some other skid steer attachments in the future, making an adaptor now may make good sense. A year or more ago someone on this forum made a pretty simple adaptor but it did not have any tilt built in. It was basically two side wings welded to a PT plate. If you can find it (he even posted a diagram) it may not be hard to build in a 20 or 30 degree tilt with a similar design.
Most any of these manufacturers will mount a PT plate at any angle you request and paint it up at no extra cost. A dealer who sells already made up units would be a different story.
HOG COOKER MTD ON S/A TRAILER (A58374)
HOG COOKER MTD ON...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
LANDHONOR LHRRM90 VIBRATORY JUMPING JACK (A52708)
LANDHONOR LHRRM90...
1627 (A58375)
1627 (A58375)
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
Transit (A56858)
Transit (A56858)
