grapple not grabbing
   / grapple not grabbing #1
Freddy Flint
Cat 257 DRW skid steer
I have a Cat 257D with a cheap grapple and I was just wondering if any one has had problems with the cylinders leaking interaly?
no external leaks anyware
but the grapple will no stay open and will not hold on to anything
When i first got it it would hold then i got something big and i felt a pop and now it leaks down
   / grapple not grabbing #3
So your "cheap grapple" has done what cheap things do? Depending on the cylinder you might be able to rebuild it, replacement is probably the way to go. Local Tractor supply should have them.
   / grapple not grabbing #4
It is possible the piston broke off of or otherwise came disconnected from the rod in the hydraulic cylinder. Does it have one or two cylinders? Best bet Is to take cylinder to a hydraulic shop and have them check it out / rebuild it.
   / grapple not grabbing #5
Quick test of the cylinder, disconnect the rod end of the cylinder from the grapple and push & pull it. You’ll learn very quickly if you got a busted cylinder. Fortunately, there’s drop in replacements if the design is basic.
   / grapple not grabbing #6
I think you answered your own question young padwan. Use the force to re-align the universe to your will. Or re-design the grapple and replace the cheap parts with quality ones.
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
2006 VOLVO L110E (A52472)
2006 VOLVO L110E...
MCELROY PIPE FUSION MACHINE (A52472)
MCELROY PIPE...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
2016 GMC Terrain SLE1 SUV (A50324)
2016 GMC Terrain...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A52577)
2015 VOLVO VNL...
