Grapple Mods
/ Grapple Mods #1
dtd24
Schenectady, NY
98 JD 1070
I had to make a few changes to my grapple. I bent up the bucket pretty good. I took a 3-1/2" x 3-1/2" x 1/2" angle and welded it along the entire bottom side of the bucket. The arm connection at the bucket braket bent a bit as well. I tried ti get away with only (2) large bolts on the end. I have added (2) more 5/8" bolts on each side of the arm connection. I think that should solve the arm connection from bending. I will post some pics soon.
/ Grapple Mods
I'll get some oics today, but yesterday I tested my new fix and bent her again. Design Flaw! I have an idea which I will share with the damage pics.
/ Grapple Mods #4
Theres lots of members here including myself that have put together grapples. I'm sure that if you post a few pictures you'll get some recommendations.
/ Grapple Mods #5
DTD,
Show some pics when you get a chance. On mine the base plate flexes a bit where the cylinder bracket connects, but so far, no permanent bending.
I was using the grapple yesterday to clear a dead tree that had fallen.
Cut it up in 5 foot lengths, and away it went to the woods. The grapple is work-saving beast, that is for sure. I thought back to the days of cutting into pieces, loading in the utility trailer, hauling, unloading by hand, etc, etc.
I am curious as to where your bend is occuring , and what forces are causing it. When I was designing mine, it appeared that varying the height of the cylinder brackets could make a marked difference in not only down force (squeezing ability) but also forces on the bucket brackets.
I wimped out, and made mine less severe in that department, given I'm using a small machine, and lightweight grapple, by most comparisons.
Let us know.
Good Luck with it!
/ Grapple Mods #6
Your killin' us man!
We NEED pictures!
/ Grapple Mods #11
I'VE GOT A FEVER! :eek:
and the only prescription.....is...
....pictures of bent steel. ;)
At this point I think dtd is toying with us. or perhaps ignoring us. :rolleyes:
Baby Goat Decorative Statue (A66738)
Baby Goat...
2011 FORD CROWN VICTORIA CAR (A66091)
2011 FORD CROWN...
2016 MACK GRANITE(INOPERABLE) (A67714)
2016 MACK...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A66736)
2008 Ford F-250...
2018 DODGE RAM 5500 HD SERVICE TRUCK (A65057)
2018 DODGE RAM...
2016 JAY FLIGHT BY JAYCO BUMPER PULL CAMPER (A67714)
2016 JAY FLIGHT BY...
