Grapple for BX or JD1025r
   / Grapple for BX or JD1025r #1
Cherokee140
Platinum Member
Kingsville MO
John Deere 650, Ford 8n, John Deere Model 70 Kubota BX25D
In the market for one of these two machines....it will be one of these two. I would like a grapple on it and really like the looks of the Land Pride SGC05. Moving brush, picking up RR ties will be a big ongoing job for this machine....whatever it ends up being.
In looking over the Land Pride site I come away that this device will only work on the Kubota....is that accurate?
If that is accurate any links or suggestions for the same type of device for a 1025R
Thanks
   / Grapple for BX or JD1025r #2
Thanks
The Grapple was made for the Bx line but should do well on the JD also
So the buckets attach in the same matter? (sorry I freely admit I am a total noob, and if I ask stupid questions) And the controls will all hook up to the JD without having to "rig" something.
   / Grapple for BX or JD1025r #4
   / Grapple for BX or JD1025r #5
Check out Artillian if you decide on JD, they offer the lightest forks made, and are coming out with a grapple this spring, lots of other options as well, he even has a plug-n-play diverter setup to operate the grapple. The Kubota and JD do NOT use the same quick attach setup, it's included as standard equipment on JD, but optional on the Kubota models I think.
Artillian Tractor Attachments
   / Grapple for BX or JD1025r #6
I'm not sure why these attachment companies haven't marketed to the subcompact tractors more. It seems like it's a market that's has great growth opportunities. The subcompacts have a similar lift capacity as that of the mini loaders and they have numerous attachments that are available. With that being said, mount one of these to your loader and you'll have endless attachment options like the larger tractors.
This works for the skid steer style attachments which will allow the MT50/52/55/463 Quick Attach attachments.
Bobcat MT50 Adapter | Bobcat MT52 Adapter | Bobcat 463 Adapter
This works for the Toro Dingo and others that have similar attachment options.
Skid Steer Mini Universal Adapter
I'm leaning towards the skid steer style as that's what my NH T2320 has and I can use the same mounting plates to build items to mount to my T2320 or my Sc2400.
Greg
   / Grapple for BX or JD1025r #7
Land Prides SGC05 grapple is made exclusively for the Kubota BX25. It will fit the FEL pin layout and Kubota's FEL QC. I did that install last week along with the Land Pride 3rd function valve.
   / Grapple for BX or JD1025r #8
If you go with the Landpride grapple and Kubota tractor you can fiance the grapple with the tractor.
Whisperwatt 45KW Towable Generator (RUNS) (A50774)
Whisperwatt 45KW...
New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
New Holland...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
2008 Mazda CX9 SUV (A50324)
2008 Mazda CX9 SUV...
2007 MACK CT713 ROLL OFF TRUCK (A52141)
2007 MACK CT713...
