Grapple designs
   / Grapple designs #11
I did it as a bucket with detachable grapple. Sort of all in one... When you don't need a grapple it's simply removed by two people
   / Grapple designs #12
Interesting project and maybe designed for a specific task. You have rare skills and ambition. No mention of steel grade. Mild steel may work on small tractors but not on larger, tlb, or skid steer. Been using/abusing grapples for decades. I’m a Pretty good fabricator, but can’t compete with high strength steel manufacturers. A grapple made of T1, 50-60 steel would have be twice as thick, twice as heavy and not abrasion resistance if made of mild steel. Would really hurt performance.
   / Grapple designs #13
Done. Wear parts are made of Hardox 500 steel, everything else is construction steel, pins are made of 4732.4 high quality steel
   / Grapple designs #14
Very well done. Good looking job. Like the welding and reinforcement design. Looks professionally built.
With the side panel extensions is there a specific material you plan on grappling?
   / Grapple designs #15
Side panels are there to hold more volume when loading light materials, corn etc. They need to be removed in order to get more reliable log/branch/waste grab. The curved design of side plates ensures a good hold
   / Grapple designs #16
Very nice work.
I bought a Bobcat LoPro bucket and built a two lid Grapple on it.
I really like the bucket plus Grapple concept. I very, very rarely swap the original Kubota bucket back onto the FEL.
   / Grapple designs #17
Any pictures of the back side with the cylinders? Sure looks great !
   / Grapple designs #18
Ofcourse:
   / Grapple designs #19
I'm a bit concerned about the strength of the four bolts that hold the claw. There's a tremendous amount of load at that point.
   / Grapple designs #20
I don't expect any problems with that. Those are 4 M20 bolts, it's strong enough
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A56857)
2014 Jacobsen AR3...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A56858)
2018 Nissan Titan...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
3 FORKS (A56857)
3 FORKS (A56857)
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Ford 8510 (A53317)
Ford 8510 (A53317)
