2310 guy
Bronze Member
This for my MF 2310. Trying to keep it light because of the small size of my tractor FEL, yet strong enough that it won't bend.
The last grapple i made ended up bending and twisting after I welded the gusits(sp) in. All the heat and my turning it in the vise ended up totally twisting my grapple. Thats what happen when you use thin steel. A blessing in disguise.
Everthing is now 3/8" or 1/2"
also I'm using angle iron because its easy and strong.
Here are the pivot points.
The pivot points before I tack weld them.
This going to be the pivoting end of the grapple teeth/arm
Teeth/arms in the mounts.
welded into place.
welded into place.
