Grapple Grapple Bucket: Bradco Utlity/Ag product good?
   / Grapple Bucket: Bradco Utlity/Ag product good? #1
Slippy
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
Looking for a Grapple bucket. Have Bradco backhoe and think alot of their products. Anyone have a Bradco Grapple bucket and willing to share their thoughts such as ease of use, primary purpose, cost, other products considered before buying, and how it has held up?
I will want skid steer to use on both my 60 and 40 hp tractors. Will use mostly for clearing brush, logs, and tree tops. I see Bradco also makes a brush bucket, and have seen the 4n1 products. Thoughts on those compared to Bradco products? Thanks
   / Grapple Bucket: Bradco Utlity/Ag product good? #2
Bradco makes really heavy duty stuff, and thats the problem with using them on a CUT. It may be so heavy that you lose so much lift capacity with just the grapple that it becomes too tedious to use.
I was at my dealer today and a customer brought back a 60" WR Long grapple because it was too heavy for his L2800 Kubota, even though it was made to fit the loader.
It may work well on your 60hp tractor with a larger loader.
as always YMMV.
My personal experience is with a Kubota L4330 and LA853 Loader, I use a Pirannah 66" root rake(approx 650lbs) with quick tach, and the loader has no problem lifting it with a load of brush or logs, but even with a 600lb implement on the back I still want to add water to the rear tires for stability because it feels too light on the back end.
hth
Leroy
   / Grapple Bucket: Bradco Utlity/Ag product good? #3
Slippy, I have this heavy duty root grapple http://www.rootgrapple.com/hdgrapple.html I have not had time to use it much, but it worked very well the little that I have used it. Moved rocks-boulders, brush and dug out some bushes. It seems to be built very good.
Best of luck /forums/images/graemlins/smile.gif
Brian
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
John Deere 843 Corn Head (A50514)
John Deere 843...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2013 Ford F-150 (A50323)
2013 Ford F-150...
2019 BOBCAT E35I EXCAVATOR (A51242)
2019 BOBCAT E35I...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
