Granite Post.
   / Granite Post. #1
Thomas
Epic Contributor
Lebanon,NH.
Kubota B2650HSD w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
What the best means of drill 1/4" hole threw granite post... post 6" x 6".
Thanks.
   / Granite Post. #3
Diamond bit, water for coolant and lots of patience.
   / Granite Post. #4
I would think that it would be the same as drilling through concrete. I have a small SDS drill that I keep in my truck all the time and use it for anything half an inch and smaller, or minor chipping and removing of tile. For bigger, and faster, I has a 1 9/16 SDS Max that is a beast.
If this is only a one time thing, then you can rent one. When my Hitachi died on me during a job, I rented a Bosch for something like $40 for a day. I wasn't impressed with the Bosch, so I bought Makita at Home Depot.
   / Granite Post. #5
SDS half in hammer drill with the carbide bit. Don't add water. Dry the dust blows out of the hole. If you do a search on this site you should find pictures of drilled granite.
[video]http://www.tractorbynet.com/forums/projects/159329-cutting-granite.html?highlight=Splitting+rock[/video]
Shows some holes drilled in granite.
   / Granite Post. #6
Granite is hard but can be brittle in small pieces. Depending on grain size. A hammer drill has a risk of cracking the post. I'd get a high grade hollow diamond drill bit and use water to cool the bit and wash away the waste. I use a wet bit adapter that feeds water into the drill bit. Will take about 30 minutes depending on muscle pressure.
   / Granite Post. #7
I'm kinda puzzled why you didn't like the Bosch. I have one and it's a beast. The only thing I don't like is the reverse paddle.
   / Granite Post. #8
Around here the lava flows will form into columnar basaltic shelves. These "basaltic posts" can be from 6" in diameter to 6' in diameter and as tall as 100 feet. They are used for many & varied projects - gate posts, yard decoration, fountains etc, etc. I've seen one local company drill one for a fountain display in a yard.
They used an automated drilling machine - clamps on to the post, positions the drill, auto feeds water based lubricant etc. The drill they used was a diamond faced coring bit. It was similar to a wood hole-coring bit. The machine would drill 10-12 inches, stop, back out and the operator would insert a tool to break out and remove the center. The tool would reinsert, drill another 10-12 inches and the process would repeat. In the end, this process leaves a perfectly round, ultra smooth hole.
   / Granite Post. #9
I liked the Hitachi a lot better then the Bosch. It had more power, felt better in my hands and just seemed to work better. For a very long time, I was a huge fan of Bosch. They invented the SDS stuff, and I was going to buy a Bosch SDS Max when the Hitachi died. But when it came to spending the money, I went with Makita and feel it was a good decision. My Bosch tools are failing on me sooner then I would have expected. My big belt sander and 5 inch orbital sander where Bosch, but now I have Makita, which I like a lot better. I'm slowly replacing every other brand that I've bought over the years with Makita. I just don't know of a better brand out there.
   / Granite Post. #10
They make diamond bits that look like flat spade bits for drilling glass and tile. they are too short to go through your post, but will give you a good start from each side, then follow up with a carbide bit. I've used them for drilling through marble...cut like butter!
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
2003 Eager Beaver 50GSLPT (A47477)
2003 Eager Beaver...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
