Grand L swinging drawbar
   / Grand L swinging drawbar #1
wmonroe
Elite Member
Southwestern, PA
1958 Ford 961 Powermaster
Does anyone have the swinging drawbar option in their grand L tractor? Mine has the fixed drawbar and when fully extended is 12” from the pto to center of the hitch pin. The industry standard and measurement needed for many implements is 14”. Just curious if anyone that has a swinging drawbar can check and see if it is 12” or 14” when fully extended.
   / Grand L swinging drawbar #2
I believe they have a drop-down draw bar that is longer then the straight one. You need to check the distance from the draw bar up to the PTO. There are some PTO shafts that will not fit due to the size , diameter, of the CV joint.
Yes, Kubota does make a longer 4” drop drawbar that also meets the 14” pto to pin hole measurement. Buying one of those is my backup plan as I like the ground clearance the straight drawbar provides. A 4” drop will catch more hay from the windrow.
2007 Western Star 4900 Semi (A59814)
2007 Western Star...
HITACHI EX550LC EXCAVATOR (A58216)
HITACHI EX550LC...
DAYTON 5500# PALLET JACK (A58376)
DAYTON 5500#...
2014 Toro Groundsmaster 4500D 5- Deck 4WD Rotary Commercial Mower (A56857)
2014 Toro...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56436)
2019 Krause...
2017 John Deere 5075E (A57148)
2017 John Deere...
