Grand L Cab.
/ Grand L Cab. #1
lawn_king
Hanover massachusetts
kubota L 3540 hsdc,B 2320 hsdc & lots of other stuff!
I have been fertilizing athletic fields this week. I just cant believe how quiet this cab is! I load up the sitrex rear pto spreader, adjust the drop gates, set my cruise control to a ground speed of 4 mph and im off. I sit back, listen to imus while i sip my hot coffee in my cold cab, life is grand! I do have to go out in the heat to refill the spreader though, its rough out there! :D
/ Grand L Cab. #2
Couldn't agree more, Lawn King. It's a beautiful thing.
Been bush hogging for the better part of 3 weeks and have to stop every couple of hours to clean all the dust off the glass. With the vent on recirc, no dust at all in the cab.
Ran over a yellow jacket nest and just backed up and put the b/h right on top of them for a few minutes, then drove off :)
Love it.
/ Grand L Cab.
Mid range high, 1100 engine rpm, rear pto at approximately 325 rpm.
/ Grand L Cab. #5
And you get paid for that ??? God bless america ! :D
/ Grand L Cab. #6
Man a cab now that would be so nice. Hope that Kubota comes out with a cab on there M59 next year. Then I can also ride in the nice cook dust free cab. While Bush hogging. Man it can get so dusty, And also bugs and stuff can and does give me a fit.
Our M95X is nice with the cab cutting and bailing hay. But it will not fit down into some of the wildlife plots where I have to go.
Pete
/ Grand L Cab. #7
1100 RRR's you must be using the cruise control lever only
I was under the empression that for contionuse use you should keep RPM's at or above 1800?
At 1100 rpm you must be sipping fuel.
Frank
/ Grand L Cab. #8
My cab is so quiet that when I'm shredding I have to look back to make sure everything is OK... can't hardly hear anything happening in the rear. Am happy about that.
/ Grand L Cab.
Frank
Im doing some more fields this weekend, i will check on my rpm, perhaps i was @ 1600. I will let you know. Just for the record, these 40 series use fuel up fast, yet to see my machine sip fuel?
/ Grand L Cab. #10
might be the comparison lawn king - my b3030 seems not to use fuel, almost. The m59 does. Can't necessarily say it drinks fast - maybe its normal, but compared to how little fuel the b3030 uses...
/ Grand L Cab. #11
Im with ya. The B3030's dont use fuel nearly as fgast as the larger ones do. My friends L5030 seems to have a LARGE hole in the fuel tank. The fuel gauge seems to have a "sweep second" hand on it in comparison.
/ Grand L Cab.
Agreed, having owned a 3030 i can say first hand they are very good on fuel. These big L's burn right through it.
/ Grand L Cab. #13
As you probably know I traded my B3030 Cab for the L-5240 Cab.
The difference between the 2 machines is Night And Day!
Fuel used is about 30% more,
But the difference is 100%.
If your budget can handle it.
Go for the Grand Series.
Frank
/ Grand L Cab.
I was not aware you took the big plunge frank, congrats man, post some pictures! This 40 series is the real deal is it not?
/ Grand L Cab. #16
You are right about the fuel, not sure that my timing was great with the cost of diesel. I told my salesman that my old DT185 would use 6gal of fuel in six months, the L3010 would use six gal. in six days and the new L5240 will use it in six hours ! But when you get in that cab and fire up that little turbo you just gotta love it !
/ Grand L Cab. #17
Hey lawn_king & Double Orange, is the cab in the grand L much quieter than the B3030 cab? The B3030 cab isn't quite as quiet as I expected, but don't worry I'm not complaining, just curious.
/ Grand L Cab. #18
Yes, In my L5240 Cab I can hear my cell phone ring. And I'm 1/2 deaf.
I've made numerous call from my Cab and when I told the other party I was in my tractor I got the old No-way response.
/ Grand L Cab.
The 3030 cab is the best you will find in that size tractor, no doubt about it. The grand l cabs are much nicer, kinda like impala to caddy, both are nice! Many a snowstorm those factory cabs saved me!
/ Grand L Cab. #20
How is old Imus???
Is he managing to stay outta' trouble??
I used to enjoy him on MSNBC.
