Grand L 3600 Glowplug Prob.
   / Grand L 3600 Glowplug Prob. #1
TV372
Litchfield County CT.
Glow plug light comes on while it has been opperating for a while. Relpaced glow plug relay problem still happens. What to look at next?
   / Grand L 3600 Glowplug Prob. #2
Hey TV, replacing that relay "always" fixes that problem. What next? Other than assuming the new relay is bad, you would have to trace the wire that turns on the light and try to see if it's shorted somewhere, also look at the printed circuit of the dash itself to see if some corrosion or other foreign material is shorting across to turn on the light. It may help, when it happens if you can stick a test light at the glow plugs themselves to see if you are actually recieving power to the plugs when the light comes on. Another thought, intermittent connection in ignition switch causing the start sequence to restart while already running/operating. Good luck on this one......
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
CROSSTECH 4200X 57" HYD BRUSH CUTTER (A51406)
CROSSTECH 4200X...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2014 FREIGHTLINER...
