Grand L 3600 Glowplug Prob.
   / Grand L 3600 Glowplug Prob. #1
TV372
Bronze Member
Litchfield County CT.
Glow plug light comes on while it has been opperating for a while. Relpaced glow plug relay problem still happens. What to look at next?
   / Grand L 3600 Glowplug Prob. #2
Hey TV, replacing that relay "always" fixes that problem. What next? Other than assuming the new relay is bad, you would have to trace the wire that turns on the light and try to see if it's shorted somewhere, also look at the printed circuit of the dash itself to see if some corrosion or other foreign material is shorting across to turn on the light. It may help, when it happens if you can stick a test light at the glow plugs themselves to see if you are actually recieving power to the plugs when the light comes on. Another thought, intermittent connection in ignition switch causing the start sequence to restart while already running/operating. Good luck on this one......
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
2003 500 BBL FRAC TANK (A53843)
2003 500 BBL FRAC...
2011 John Deere 120D (A47477)
2011 John Deere...
1991 MACK RD600K HOT OIL UNIT (A53843)
1991 MACK RD600K...
2015 New Holland Boomer 47 4WD Agricultural Utility Tractor (A53421)
2015 New Holland...
