Grading grading ?
   / grading ? #1
Jksnvly
Endless Mntns of Pa.
I'm building a second home in the 'mntns' and will need to do some final grade work on the lawn area and also in my orchard, where a pair of wayward pigs tore things up last Fall. Will a york rake suffice? or do I need a rear blade?
I have a 'virgin' 2320, chomping at the bit...
   / grading ? #2
The area you want to grade will have to be tilled up first before you can use either the rake or blade unless the dirt is already loose. I'd go with the landscape rake it will give you a better finish and get it ready for reseeding.
   / grading ? #3
If you already have a York Rake- try it. I would try a box blade or a 3pt blade for initial grading and then the york to finish before seeding.
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2022 JOHN DEERE 320G WHEELED SKID STEER (A51242)
2022 JOHN DEERE...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
