Grading an agility field
   / Grading an agility field #1
mbgt2003
Kubota
I'm currently grading an agility field (80x120')
which is about 2 feet lower on one site.
I started moving dirt with the box blade but it is very messy to run over the accumulated dirt every time when I bring another box full of earth downhill.
Any suggestions on a more streamlined approach.
MB /forums/images/graemlins/confused.gif
   / Grading an agility field #2
If you lift the blade very slowly as you drive, it will spread the dirt in flat sheets, and as you drive over with more loads it will help pack it - which is a good thing! Two feet of dirt dumped in uneven piles is going to settle out kinda lumpy.
What is an agility field?
--->Paul
   / Grading an agility field #3
Be patient you will get much better at this as you practice. I was having the same problem for a while but practice helped a lot. Now I use my position control to feather it out much more evenly.
Thanks for the encouragement.
An agility field is for dog agility trials.
Running over hurdles, jumping, tunnels etc.
MB
   / Grading an agility field #5
Have a FEL? Maybe move the dirt first and then level. Have a dump trailer or truck or some way to move the dirt?
Wouldn't a scraper blade pull more dirt than a box blade? Then use the box blade to level it up.
   / Grading an agility field #6
Well, my 250'x200' Schutzhund field isn't quite level, but it is smooth. Our jumps are limited to a 1 meter brush hurdle and a 1.8 meter A frame with 1.9 meter sides. But we also have 90 pound dogs making contact with the bad guy at about 30 mph.
I cut down several hundred small trees in early spring, and had a dozer push all the stumps for me. I graded and raked my field in July, when it was as dry as possible, and seeded just before a gentle multi-day rainstorm that the weather-guessers got right.
If you really feel it has to be perfectly level then I would talk to somebody with a dozer. I would be concerned that if you don't plan drainage up front then it will be soggy a lot of the time. Of course, this depends on your local soils and climate.
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2014 Caterpillar 289D High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
2017 TROXEL 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 130...
2015 Ford F-450 Flatbed Truck (A51691)
2015 Ford F-450...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
