Grader
/ Grader #21
The one thing that I noticed about yours is the blades are straight across, which means you are only doing flat leveling. For some, this grader would be for their driveways, and mounting the blades at an angle from side to side would allow you to crown the road. The amount of tilt on your top link and the angle of the blades controls just how much crown.
I have seen where some people mounted them straight across like yours, but raised them 1/2 to 1" on one side, which means they will never be able to do flat leveling. I like the side to side angle because you can do both with it.
Although these types of graders appear very simple in design, there really is a lot of engineering built into them if you want them to work very good, to great, or not at all.
I would also like to see your notes when you get them scanned, as this is a project I started accumulating stuff for, and then didn't need the grader. I think I should put the stuff to good use, so I may go ahead and build the grader one day.
David from jax
/ Grader #22
this is the scrub, it does a good job, the wear edges are reinforced with recycled grader blades.
/ Grader #23
Hey laurencen ,
Down here in Louisiana, we call those Bionic blades. I noticed from your pictures that your front blade was angled way more than your rear blade. We do just the opposite down here. May want to give that a try. My brother and I built one that is 7' wide and we made the front blade where it can be 1" below the edge, even with the edge or 1" high. It is amazing what you can do with one of those blades.
Mike
/ Grader #24
Yep, great job:)... put me down for a copy of the plans.... it'll make a good welding project. I already have the grader blades, just need some other metal and I know where I can get it.
CEDARAPIDS HEAVY DUTY ROCK SORTER (A66734)
CEDARAPIDS HEAVY...
2014 International 4300 DuraStar Crew Cab Knapheide Utility Flatbed Truck (A68183)
2014 International...
JCT 72" Skid Steer Rotator (A64912)
JCT 72" Skid Steer...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
12ft T/A Flatbed Utility Trailer (A64553)
12ft T/A Flatbed...
LIPPMANN HEAVY DUTY ROCK SORTER (A66734)
LIPPMANN HEAVY...
