grader
/ grader #1
jack707
up North wisconsin
farm trac 555
I have a driveway (dirt) that's about 1/2 mile long with potholes! and I am looking for a grader to use to smooth things out in the Spring time. The one I'm looking for will be pulled by a ATV so can someone recommend a brand?.
/ grader #2
I pulled an ABI Gravel Rascal (RG 4.5) behind my Kubota RTV500 (15.8 horsepower) with satisfaction.
Pulling the Gravel Rascal is high draft work. You will need at least 15.8 horsepower and four wheel drive.
Kubota RTV500 HST transmission was an assetl Used HST/LOW + four wheel drive for pulling dirt.
LINK:
ATV Driveway Graders - Gravel Rascal® - ABI Attachments
2015 Ford F-150 Ext. Cab Pickup Truck (A66736)
2015 Ford F-150...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2013 MACK CHU613 (A67714)
2013 MACK CHU613...
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
2025 28in Forks and Frame Mini Excavator Attachment (A66734)
2025 28in Forks...
BRADLEY MACHINE  MINI VAC TRAILER (A67714)
BRADLEY MACHINE...
