GRADER FOR DRIVEWAY MAINTENANCE
/ GRADER FOR DRIVEWAY MAINTENANCE #1
DaveBittel
Toolcat 5610
My setup.
/ GRADER FOR DRIVEWAY MAINTENANCE #2
Here is the type that I want, SSQA or 3 point:
/ GRADER FOR DRIVEWAY MAINTENANCE #3
Interesting setup Dave. Appears to be doing a good job. Side note - I've NEVER been in a place where you can look so far and not see mountains - your bottom pic.
/ GRADER FOR DRIVEWAY MAINTENANCE #4
I have always felt that a well designed 'drag' does as good (or better) a job than much pricier attachments.
Problem is that nobody sells drags, you have to DIY your own.
Now if you weld it is a nice and easy project.
/ GRADER FOR DRIVEWAY MAINTENANCE #5
Piloon - how VERY true. After spending $$$$ on a fancy LPGS - I built this. My home made drag probably cost me $20 and will do most everything the LPGS does. A little slower but the driveway still ends up smooth. The heavy spikes - fore and aft were an expensive option - added $10 to the total cost.
I’ve made an upgrade since pics with it on the Toolcat. Still plan on a Tiltach in future.
LOL, my funny side note. When my sister lived in Maryland, when visiting, after a few days I’d start feeling “ claustrophobic” because I couldn’t see horizon to horizon for all the trees.
Rainy day project. Built sacrificer using teeth from my box grader.
/ GRADER FOR DRIVEWAY MAINTENANCE #10
2 BALE HAY SPEAR (A63291)
2 BALE HAY SPEAR...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 CHEVROLET SILVERADO 2500HD (A63569)
2013 CHEVROLET...
Mini Skid Steer Pallet Forks (A64047)
Mini Skid Steer...
